 DIY 55W HID Projector retrofit Squadron killer
PostSubject: DIY 55W HID Projector retrofit Squadron killer   9/27/2013, 10:51 am
So the stock FE390 headlight is dull..
$70 will fix that.
Get the 4300K bulb version. 4300 is the brightest.
http://www.ebay.com/itm/151100173994?item=151100173994&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
3" hole saw in reverse direction... centered on the little circle on the middle of the lens. Then filed out enough to fit the projector
like a glove.
Low beam
high beam
Hooked up the halo to the running 12v wire on the bike.. whenever bike runs so does the halo
The brown wire on the left connector is the 12v acc power you want to tap into
All wired up, plug and play. The ballast +/- goes to the little running light power. The high beam wire goes to the high beam coil. The low beam wire is unused.
Projector HID on left, Squadron on the right. The Squadron has a very tight hotspot, and outside of that there is not a lot of light. The HID is very well filled in all around, with a nice hard cutoff above the horizon. Much much better for trail riding and not blinding traffic.
for comparison.. stock WR450F headlight.. and it is better than the KTM/Husaberg stocker!
Focker
PostSubject: Re: DIY 55W HID Projector retrofit Squadron killer   9/28/2013, 12:06 am
Great job!
I'm looking at lighting options on my KTM 450XC.
Do you have a stock stator?
How long did it take to receive from China?
http://www.xr650rforum.com
PostSubject: Re: DIY 55W HID Projector retrofit Squadron killer   9/29/2013, 6:25 pm
thanks. took about a week. Husaberg stock puts out 220w
PostSubject: Re: DIY 55W HID Projector retrofit Squadron killer   10/10/2013, 9:33 am
So you decided that you didn't like the Ebay HID conversion?
PostSubject: Re: DIY 55W HID Projector retrofit Squadron killer   10/10/2013, 12:28 pm
That one works fine, this is just better.
