 Skid Plate Build
YAMAHAULER
Bike : '81 XT500H, 2005 XR650L, 83 Big Red
PostSubject: Skid Plate Build   1/17/2011, 7:06 pm
I havent really found anything that floats my boat for skid plates and mounting. The big bosses are out of town this week so its a good time to attack this.... peepwall
The begining stages.
PostSubject: Re: Skid Plate Build   1/17/2011, 7:46 pm
I think cardboard might fall apart the first time you hit water. wink Maybe upgrade to Styrofoam.
PostSubject: Re: Skid Plate Build   1/18/2011, 7:05 am
Styrofoam will help it float tooooooo!!
Brilliant!
Bike : '82XL500R
PostSubject: Re: Skid Plate Build   1/18/2011, 5:56 pm
The cardboard will work fine after he adds the duct tape. Duh. Troy341
YAMAHAULER
PostSubject: Re: Skid Plate Build   1/18/2011, 8:26 pm
Concerning the last three replys.
Reinrod
Bike : Austrian Jackhammer
PostSubject: Re: Skid Plate Build   1/18/2011, 8:59 pm
Looks like you're off to a good start. Going to use 3/16? Have fun. bananna
YAMAHAULER
PostSubject: Re: Skid Plate Build   1/18/2011, 9:02 pm
Yeah using 3/16...I have the pieces cut out now. Hopefully cant start putting some shape into them tomorrow.
PostSubject: Re: Skid Plate Build   1/20/2011, 8:00 pm
That's gonna look good!
PostSubject: Re: Skid Plate Build   1/20/2011, 8:05 pm
Crud, I followed the Curvy Road and there isn't any skid plate fabrication yet.
Fib
YAMAHAULER
PostSubject: Final Assembly   1/21/2011, 8:24 pm
So after tracing out the cardboard shapes on to 3/16 aluminum plate I cut them out on a band saw and touched them up on the sander. Then I made a template to get the right curve for the bottom piece. The two side plates were a little more tricky as they are a compound mitre. They required a little more massaging and patience. Overall they were both a good fit to the center piece. The black lines were used for bend lines to keep them similar in shape and a good starting point for shaping the side plates.
More tweaking and eyeballing led to welding the pieces together. (didnt use a tape measure in this build except for the two mounting holes in the front) My tig welding was a little sub par in the looks department but it will hold together just fine.
I havent tigged in about year and half .
I wanted to use all the same mounting brackets that the original bash guard used so I made a couple of little tabs and drilled a couple of holes to make that happen. The right side of the origanal bash guard used a bolt to go through the frame and was nutted on the inside. So I just tapped the hole to a 5/16 and put a new bolt in to make it work. I will eventually drill some strategic holes for air flow but wont put any holes in the bottom of the skid plate like the ones you buy. When I draiin the engine oil its no problem to pull the four bolts that hold it on.
I guess i'm ready fot the Odessa rocks now! thumb
PostSubject: Re: Skid Plate Build   1/21/2011, 9:38 pm
cheers Saweet!
Just the fix I needed for a Friday night of cabin fever.... Hello
goodthread
PostSubject: Re: Skid Plate Build   1/22/2011, 3:27 pm
Wow. Dude, that looks great! thumb
Bike : '82XL500R
PostSubject: Re: Skid Plate Build   1/23/2011, 5:42 pm
That does look great, burly too. Looks way better than the cardboard and duct tape one you were gonna make. Troy341
YAMAHAULER
PostSubject: Re: Skid Plate Build   1/24/2011, 8:21 pm
griz901 wrote:
cheers Saweet!
goodthread
Thanks.... big
09kevin
Bike : 2009 ktm 530 exc
PostSubject: Re: Skid Plate Build   1/24/2011, 9:39 pm
Nice job thumb
Skid Plate Build
